84 Cutlass Supreme Brougham
84Fourdoor
Jul 18, 2011
53
Hey guys I have an 84 Cutlass Supreme Brougham sedan on my hands. She is my first car. My friend and I took her to a shop to have a thorough inspection of the car to see what all wrong. We received a list today
New alternator and brake adjustment - $185(Already done to car)
Valve cover gasket, new oil filter, lube - $195 - I need explanation
Transmission pan gasket, new filter - $129
Universal Joint replacement - $175 - I need explanation
Left front Brake caliper and rotor - $143
Spark plugs and wire set - $167 - Since this is an easy fix, I think my friend and I are going to do this.
Could somebody explain all of this? What all on the list is easy to do? I am next to clueless when it comes to cars, but my friend is a licensed mechanic, so he's gonna help me out a little along the way.
changing your brakes and rotors is also very straightforward. it's seven bolts. and five of those bolts are your lug nuts. only requires pads, rotors, 2 wrenches, and some grease.
Valve cover gasket, new oil filter, lube - 195 - Basic oil change an filter.. $30 ; unscrew plug from oil pan, remove filter.. replace filter filll with oil..Gaskets are about $15 bucks. Remove 4 bolts from valve covers clean up head where where gaket sits and replace.. might have to move a few things out the way but nothing hard.
Transmission pan gasket, new filter - 129 --Gasket and filter around $20+cost of transmission fluid- remove transmission oil pan drain oil replace filter and put in new gasket on pan. (a little more difficult but still very easy).
Universal Joint replacement - 175 - this is fairly simple just a few bolts and nuts and remove old u joint and replace.
If your friend knows his way around some tools. I really dont see why you guys cant tackle it all 🙂
Sorry missed one lol what othim said and changing caliper and bleeding the breaks and your good to go 🙂
Don't forget about the spindle nut to get the rotor off, and repack the bearings :mrgreen:
I just talked to my buddy and he said we could do it. Now I need to find the parts. Where would I be able to find the parts numbers that I need for this car?
These parts should be easy to find at your local Autozone or wich ever parts store you prefer.
Would I be able to find better prices at an online parts store, or a local parts store?
Should be around the same with shipping and all. I would just go to a local store.
