I have a 1984 Oldsmobile Cutlass Supreme 307 V8. The previous owner started noticing that the battery was draining overnight. It has been going on for almost 10 years. I did some engine work that involved removing the heads, and when I put it back together, the ignition was shorting out. It was cranking like the battery was almost dead. I checked the engine wiring and found nothing. I then pulled the entire dash out of the car, and noticed the pink wire leading from the ignition switch on top of the steering column was reading a short when checked with an ohmmeter. This is the only lead that I have on the problem. Any help would be greatly appreciated!
