84 cutlass v6 to 72 olds rocket engine swap questions
jaytee801
n00b
Aug 16, 2012
i am changing out the v6 to a 72 olds 350 rocket in a 84 cutlass i was wondering what motor mounts do i use ? also does the drive shaft have to be modified ? im using a 350 trans short shaft and what about the transmission cross member any changes to that ? thanks in advance for the help
You Need: v8 frame motor pads from 78-88 gbody with olds v8. Move fuel lines to other side. Move battery to drivers side. Get motor mounts for a 78-88 cutlass with 307 or 260 olds. Gbody v8 radiator, fan shroud, top plate. if you had a 3spd th-200 trans, a th-350 is a direct replacement. Edit: bill found ya a link while I was thinking back about my previous swap, I did the same swap.
Hey Evans....can you read that post and add anything that I might have missed. Im trying to create a thread for those who are thinking about this swap since theres only sticky threads for the sbc swaps....thanks!
Yep I will
