84 olds build
cutty
207
near london ontario canada
picked this up for $700 without a motor,car had lots of work done just before i got it,as in new brakes,lines,ebrake cables, front susp all new, body is decent,floors and trunk pan are super clean,now has a 83 chevy 350 been bored 30 over with flat tops, comp cam 480/480 cam(brand new just put in)heads are double humps ported polish and bowels have been cleaned up,has screwed in studs with guide plates and new springs,new comp cam hardened push rods,roller rockers,edelbrock rpm intake with a holley 750 vac secondaries carb( was just rebuilt) choke horn has been milled off,has arp head bolts,headers, ive been taking my time with it as i wanted to do it over winter, but needless to say ive almost got it running stage, heres a few pic's i dont have a whole lot from when i got it, but do have some showing where im at now
Too bad it's a Chevy motor but whatever works for you. It's still a very nice car that I'm sure will be a ton of fun to drive 🙂
Didn't mean any direspect, I forgot that the Canadian cars came with the 305. It is a beautiful car and I can't wait to see it finished.
Thats a good looking car and good looking motor. I bet you can't wait to burn some rubber.
hope to break in the cam as soon as the rad shows up, and no didnt feel disrespected, was just sayin it came with the 305 all good, lucky for the tires its winter up here lol, or they would be bald pretty quick lol
Great snag for $700. You even got buckets console & looks like ralley guages. You know you can make some type of conversion parts from the salvage yard so that you can hook your factory guages up to work like the tach & oil pressure. I did this on my with Caddy motor. You also got a nice color, ralleys, and a rear spoiler. You did good.
The tires look good but if you burn off the rears BFG makes a RWL 245/60/14 that looks bad arse and would go with your fronts. Is your carb and filter going to fit under the hood? If you want an inexpensive solution and would like to make it functional check out my pics. You might consider getting the trim pieces and getting rid of the top as it looks done for.
Shoot you even have a cool rally steering wheel. If you still have that crappy metric 3 speed you might look for a 200-4r as it would be a drop in and probably the single best upgrade you will make at least if you ever drive her on a highway. You get both the benefits of being able to use quarter mile gears and not rev the snot out of it and waste fuel going down the road. Plus you can use a higher stall lock up converter to take full advantage of your cam without sacrificing drive ability mileage or putting excessive heat load on your cooling system like a regular high stall converter would do.
Edit If you snag a 200-4r before you put the motor back in I would while you have the trans out have a shop put in a good shift kit for you. It will be a little time and a little money well spent. http://www.ckperformance.com has an excellent one which they sometimes discount to $100 if you ask them about it. Cheap shift kits for the 200-4r that you find at the autoparts stores are well you get what you pay for.
its got a turbo 350 in it now, ya the top is has seen way better days,im getting a new 1 put on in the spring, ya the carb and air breather both fit under the hood no problems
little update,
got it running just fine tuning it, thought i would be able to get away with using the old turbo 400 mufflers
but after 1 good run with it that was the end of that, blow out both baffles, heres a video with old mufflers
http://www.youtube.com/watch?v=IN4gwDNOM1I
and heres with my new 1's, i was shocked as to how they sounded, i heard them on my buddys car and wasnt to impressed,
but thought oh well they are cheap enough, but wow was i wrong,huge difference, anyone wants to guess as to what they are???
http://www.youtube.com/watch?v=FC8xh3qxFo4
cutty said:
little update,
Very nice. Sounds a little bit like mine. What's the lift on that cam?
