85 Regal brake problem
What does the pedal feel like? Is it soft until it gets to the floor? I'd be willing to bet you need to bleed your brakes or you have contaminated fluid. When was the last time you checked your brakes? Make sure your not leaking fluid, check drums especially.
Yea my brakes are soft until it gets to the floor. I never checked the brakes yet. I just recently bought the car. So can I bleed the brakes myself or do I have to take it to a shop? By the way thanks.
CHECK FOR A LEAK!!!!!!
Regalnomics said:
I'm positive that there is no leaks.
To be completly sure your going to have to pull off the back drums and check the cylinders. If there is a leak it could be inside the drum and you wont be able to tell unless you have it off. If you do that and it is dry inside then I'd start by bleeding the brakes. I'll give you the play by play on that; but first what does your fluid look like? Remember brake fluid is distolic, meaning that it asorbs water. If the fluid is contaminated with water it will lower the boiling point and you'll have very poor braking. Or if there is air in the lines then you wont have any pedal either. I'm guessing you have one of these two problems. Its easy to fix just let me know.
Oh my bad I thought the leak was suppose to be outside the car. Ok I'm a try to check the cylinders right now.
