A while back I had an issue with my Cutlass. Decided to let the car run, since it hadn't run in about 3 months. Was running in the garage and the car stopped running after about 20 minutes.
The temp was pretty high since it was in the garage, but no hose blew. No leaks .
Afterwards the car wouldn't start. Someone on the forum told be to check for a spark by pulling the 1st spark plug and checking to see if i was getting a spark. Nothing.
Per the recommendation, I installed a new coil and I got the car to run for about a minute (THANK GOD I DIDN'T BLOW UP THE ENGINE) ... then it just stopped again. Won't start. Just cranks.
Not sure what it might be. I just bought a new distributor cap and rotor and will see if that will help.
Questions:
1) Is it easy to burn out a HEI coil? I found a video that shows how to check the coil with an Ohm meter and it appears to be "OK".
2) I have a feeling there may be an issue with the grounding strap from the distributor. Maybe?
3) Is there anything else I should be checking?
Questions:
