I have the fuse block and bulk conn. apart, found D5, I got it out and it won't fit in C6
Also it has 2 drk green wires on it.
Am I doing something wrong? or is this maybe the wrong wire?
Thanks for the help
The Coolant Temperature Sensor
Thanks for the help
- Method 2 (Harder)
This method will alleviate the need to change the Coolant Sensor if your engine has a two terminal Coolant Sensor.- Remove the two screws from the opposite corners of the fuse block
- Pry out the tabs at each corner to seperate the fuse block from the bulkhead connector.
- From under the hood, loosen the 1/4" captive screw in the center of the bulkhead connector holding the two halves of the buckhead connector together.
- Pull the bulkhead connector apart
- Remove the terminal at D5 (Dk Green or Dk Green/Yellow)
- Reinstall this terminal at location C6
- Reassemble the bulkhead connector and the fuse block
