86 cutlass suspension
t hare
n00b
Mar 27, 2014
55
Athens, GA
Hi everyone i'm Tony. New member and I have a 86 cutlass. It's got 24's on it with air shocks on the rear. My problem is my shocks won't hold air. I've switched shocks twice and both times changed the air lines and they still drop in about six hours. Does anyone have any suggestions?
Fill a spray bottle with dish soap and water, you only need a little soap. Fill the shocks up to the max PSI, then spray all the fittings and the fill valve. Any leak will cause the soap to bubble up.
I have a 1982 Monte carlo with Air shocks in the back but check the air insert nossel where you put the air in at and the connection of air lines behind it and yea spray it with the soapy water>>>>>>>> u should find it!!!!!!!!!!! IM NEW TOO But i know a lil something.
