Just got my first Monte Carlo SS. Always wanted one of these or a Regal.
The car is an 86 Monte Carlo SS with 68k miles. It has an LM7 5.3 mated to a 700R4. It’s got T-Tops (I didn’t want that), a grey interior with new carpet, and most interior pieces have been removed and refinished, and need to be reinstalled. The car was taken off the frame at some point, all body bushings replaced, the entire frame painted in POR-15. The floor appears to have two patches done towards the front outer corner of the driver side and passenger side. There is some rust along the rear lower fender and along the bottom door edges. The car has “15-footer paint”. It was resprayed at some point.
Immediate action:
The car needs radiator fans - in process of wiring dual electric Dodge Intrepid fans
gauges wired up
Mount PCM and tidy wiring
Install air intake
steering wheel alignment (it sits like 90 degrees off center) - should I remove the steering wheel and reinstall at a different angle or does this alignment need to be done elsewhere?
Rear tires - need a pair of 255/60/15
Is there anyway to remove the old fuel without dropping the tank? Siphon maybe?
Here are some pics as she sits now:
Immediate action:
gauges wired up
Install air intake
