Hello,
I've recently been having problems with my 86 Regal. It has a 307 which is still computer controlled. The car has been stalling like its running out of gas, then sometimes won't start for a while or won't start unless you crank it for a minute or so. The electronic Q jet has been rebuilt, and the fuel pump has been replaced. Sometimes it will run fine, then out of no where it starts sputtering and stalls. I have driven it several times when it would stall, restart and drive fine unless under a moderate load, other times it stalls then restarts, and as soon as you put it in gear and accelerate lightly it cuts off again. I'm not sure what I'm missing, has anyone had this problem? BTW, I know it's not the carb as I've switched it to a known good one and had the same results but its definitely a fuel problem. (Carb jets won't squirt when this happens, like float bowl is empty). Could it be a defective pump? Or a cracked rubber fuel hose somewhere sucking air? Please any insight is greatly appreciated.
