Well we got back to it a couple nights this week. We got the hydroboost, master cylinder and pedal stuff back in there and bolted down. Got a new cotter pin(actually an assortment) and got the pedal hooked up to the actuator rod on the hydroboost. Actually, you need to hook the rod up before you bolt the pedal bracket back in there, or at least we did as I couldn't get the rod onto the pedal pin with the bracket bolted in. Your results may vary.
For those wondering I took a pic of the length of the pin cL to cL on the pivot
Also got one from the end of the pedal to the actuator pin cL
booster and master cylinder bolted in.
I got a tee, some hose and a chinese flare wrench to try to get the hose from pump to steering box off. I looked for a snapon or matco man all week and stopped by harbor freight to see about a flare wrench or some crow foot flare pieces but came up dry so I bought the duralast at the auto zone by the house. I looked at the sears stuff too and called the store but they said they didn't have the single or the set in stock and the last time i went over there most of their stuff was marked china so I doubt Ill be buying much from them when I can get Chinese junk anywhere.
I thought this was funny. In white at the top of his window it sez "Imports Suck"
