88 cutlass supreme wont idle in drive
86MCSS86
47
8
Once again I need a little help here. The car is an 88 cutlass supreme classic it will idle in park but as soon as you put it in drive it shuts off. It will shut off on you at every stop too. I have replaced fuel pump, fuel filter and a few broken vacuum lines. What can be causing this. Thanks
Lots of things can cause that symptom. A vac line could be connected to the wrong thing for 1. The ash can could be chock full of ashes. The intake manifold could have a leak. The ignition switch behind the steering wheel could have a faulty wire, the battery terminal cables could be fried, the battery could be putting out 10 volts or less, there could be a bad solenoid or just plain loose wire touching another wire or crimped somewhere, or the alternator could be either going out, or the belt just has too much slack in it. The pin that opens the door to the carb could also be not opening it all the way, forgive me I forgot what that' part is called, lol Start with the cheapest of these problems to fix in order. For example the ignition switch is like $5 or less everywhere, although not everyone has the steering wheel tool.
I replaced the intake manifold gasket about a month ago the car ran fine after that. I sprayed starter fluid around vacuum lines and around the intake manifold and it didn't change the idle so I think there are any vacuum leaks. I did notice that the smog pump isn't throwing out air but it was before. Can a bad smog pump cause this?
