Hey everyone, I have a few questions about my car. I figured since a lot of you guys have much more experience with these cars that you could save me some headaches.
First, I am going to be removing all of the body trim on my Cutlass, it has the lower chrome rocker mouldings, and a small mid-body trim piece that runs from the front fender, across the door, and half way to the rear wheel well. I have seen this moulding/trim on most cutlasses from the factory, but I have seen where a lot of guys have removed them with out re-painting(or so it seems). It looks like this mid-body moulding/trim is only glued to the car? If so, is there a good way to remove it without damaging the paint underneath? For example, should I try to heat the trim up and then remove and de-grease to remove the glue?
Second, the clear coat on my car has started coming off, in the usual places, the hood, roof and trunk. Is there any way to stop this from peeling? I plan on a new paint job in the same color(light metallic blue), I'm just trying to keep it from becoming any more damaged before I can get it painted. Which will be in the next 3-6 months.
Any help or tips will be greatly appreciated.
Thanks.
Thanks.
