ok..something new...
I found a 9" Ford rearend , which was modified/built(??) for a Caprice , ( b body?) from around 1985... I think it is not that wide as it should be...
So , is it possible to put a caprice rearend into a g body?? If that is possible , it should be possible to put that rearend in my 78 Cutlass !?!? Are there any special parts neeeded??
Where are the differences between them??
I would get the whole rearend incl. all trailing arms , swaybar panard...and driveshaft ,complete disc brakes and so on..The rearend ist out of a police car which was used for a stunt show...has spool or limeted slip diff and all the good things!
Thank you for any help..it is not that easy to get anything here , so that might be a chance for me !!!
Carsten
Carsten
