9 INCH Swap
EffendiCrux13
16
38
West Palm Beach, FL
getting ready to do a rear end swap. wondering if anybody knew if someone sells all the brackets new, i can take the old ones off the 7.5 but don't feel like being that meticulous. also is there any stock ford disc brakes to do a conversion ?
thx effendi
you can buy brakets on ebay for doing the swap around $70.00...its a simple setup wont take you long to mod up...as for the disk brakes for the rear there is alot of setups out there . i need some more info on the flange type and what size bolts it uses (1/2" or 3/8")...... your better of going with a 3/8 big bearing bolt flange reason being there is modern day brake kits also make sure of the axle backspace 2.50 would be best .
EffendiCrux13 said:
Thx nycutlass. I will get some measurements and get back to you.
Thx Effendi
no problem at all
