I'm in the process of re-installing the A/C components in my 85 Cutlass and also converting from R12 refrigerant to R134a refrigerant.
The new compressor has a high-pressure blow out disc. In most of the retrofit instructions I found online, it says to replace this blow-out disc with the high pressure switch from the old compressor. Well, I checked the original stock R12 compressor that came with the car and it doesn't have either.
So can I just keep the blow-out disc in place? Will this work for the 134a conversion?
