Has anyone ever converted their cutlass from the dying r12 to the new r134a? How it work out and how much did it run u my mechanic says i need a whole new r134 ac system that runs about 1200 is this true or is there a cheaper route i can try first
tc1959 said:I have done automotive AC for a long time . It has been my experience that quickie cans of stuff don't work very well, for very long. The compressors always grind themselves up and they all leak,134-A is able to seep past R-12 seals and ,hose.
Most of our cars were designed for R-12, They have single barrier hoses, smaller condensers, different desiccant in the dryer/accumulator, and use 5w5 mineral oil.
134-A systems use different seals and hose. The compressors have heaver valves and swash plates.They use a bigger condenser. and run at higher pressures, It also requires a synthetic oil called PAG oil.
To do a proper AC conversion will run over $1000 to $1500 .
I do about fifteen a month and that's just about right on . (fords & some foreign cars are even more )
I kept R-12 on my own car when I changed over to a serpentine drive system.
There is no such thing as a magic fix in a can that will perform like a properly done conversion.
bread said:tc1959 said:I have done automotive AC for a long time . It has been my experience that quickie cans of stuff don't work very well, for very long. The compressors always grind themselves up and they all leak,134-A is able to seep past R-12 seals and ,hose.
I am sure you are correct on most of your statements, but I will say this: R134 leaks past the correct seals much faster than R12 due to the molecular make-up. When I went through licensing for AC service back in 1997, I was told that R134 systems would need to be recharged every 2-3 years. My experience says that is about right. But R12 could go a decade.
I have used R12 and 134, I have mixed them, and I have used generics (be-cool). I have never had a compressor failure. My olds has had be-cool in it for 15 years on the factory compressor and still no issues. So why spend 1000-1500 on a complete swap? I mean, if the refrigerant trashed the entire system that would be the repair bill. So why not chance it? I do draw the line at propane, however.
"Well you can never afford to do it right, But you can always afford to do it over" 8)Kutdoctor2k11 said:Thanks everyone for your opinion ALL is appreciated just wanted to make sure i had this right however so i can go the cheap route have ac and risk it failing on me in as few as a couple months or the expensive "correct" and get a completely new r134a a/c system and be confident that it will last me for years to come. Budget is never a problem as long as i save for it just wonder if weeks and weeks of saving is worth it when some think that the cheaper route is just as effective
