Last fall I finally hooked up and charged my ac after the swap. I’ve run into two issues that I’m hoping someone may be able to help me troubleshoot, or at least point me to where I should look.
Following the instructions on LT1swap.com, I created new wire runs for the ac controls into the ecm. Issue #1- When I turn on the ac, if I connect the low pressure switch, the compressor runs on every position on the hvac control. If I unplug the low pressure switch, it comes on as it should with just the ac selection
Issue #2- my fans aren’t turning on with the ac. This caused me to blow the high pressure relief valve while sitting in traffic on Sunday.
On Monday I verified that my wires are running to the correct ecm pins. It started pouring rain before I could investigate the relay wiring. But could there be something else I should look at?
For the fans, I know that I have to verify they are switched on for ac in the tune. I can’t remember if I requested that when I sent away for the initial tune. Is there something else o should look for?
Thanks for any help/direction.
