Need some problem solving help in understanding what is going on with ’84 El Camino. Have read many threads here but none seem to describe my problem. All control panel settings direct air where it should go, but with one problem – there is always air coming out of the heater vents, even with everything turned off (both levers are fully to the left). Some detail below but necessary:
- Car does not have vacuum controlled heater control valve.
- No vacuum leaks
- The heater vent air volume is car speed dependent; with more air blowing the faster the car is going.
- With everything off, the air is hot as if the heater is on.
- The AC/Heater door is, I believe, fully closed to block heat. That is, the threaded rod attached to the AC/Heater door is pushed in toward the firewall as far as it will go (I’ve pulled the rod out of the holder clamp and have confirmed this, but have no way of visually confirming the door is actually moving although it appears to be).
- When AC is on (set to Max, Normal, BiLevel or Defrost), the air from the heater vents is cold.
- The re-circulate door is closed on Max and open on all other settings.
Any ideas on what I can check or do to stop the heater vent air flow? Need to fix this because it really gets hot in the car when AC is off.
- No vacuum leaks
