Thanks for reading needing help. I habe a 1983 Buick Regal Base Model 3.8L V6. I replaced the oil pressure switch, coolant temp switch and sensor along with coolant recently. Got everything back together and my gas peddle is pulsing/ clicking when in drive. Literally you can see it pulsing and clicking. When you accelerate it stops but but can notice it if you let off. Also does it while at a stop pushing on the brake but stops when you put it in park or take it out of gear. Not moving at all just starts doing this when in drive. Engine light is on just not sure if s scan tool could hook up to it and read codes on it. It drives good just not sure what could this be? Everything seems to be connected. I believe it's a 2 barrel carburetor but not positive 9n how to tell. (Tried to upload a video but no luck.)
Thanks for any help
Thanks for any help
