Ahh! my car has a bad lifter!
6,128
13,321
i found out the dreaded news today as i was performing surgery on my 87's v6. i was there to retorque rocker arms, but when i pulled the valve cover, i noticed a pushrod had slipped off of its rocker arm. so, i went about my retorquing business anyway after correcting the problem, but, i checked the tightness of that rod when i was done, and it slipped off again. oh s***. bad lifter. is there anyway i can replace that lifter without removing the head? if i have to pull the head, i may as well pull the engine, put in a 350 and rip out the computer. i know on some engines you can pull the lifter through the intake manifold hole with a magnet on the end of a rod, but im not sure about the buick 231. does anyone know? has anyone done this before? if so, any tips?
I know on the SBC and i believe the buick is identical. you just need to take the intake off and you can pull it out of the valley.
X2 either you can compress the valve springs to release the tension to get the pushrod out or you can take the rocker arms off.
