So i just finished my engine swap a while ago. I took it too get a emissions test so i could renew my tags and.....FAILED! Reason why i failed was cuz my car was running rich. It was high on HC and CO which could be contributed to the carb not being adjusted lean enough and a few vacuum leaks i found . I also failed the visual inspection on my air injection system. From what i was told it was missing parts or disconnected. I know the air injection system has two hoses going to the air injection pipes that screw on to the headers. another hose goes down to the cats, but my question is where the other port on the diverter valve goes to. I thought it goes to the air cleaner but there is no place to plug the hose in on it. My car originally was missing a bunch a of smog equipment when i acquired it. It passed the test last year both the dyno and emissions portion but not this year! So i need to find where that port goes to, I am pretty sure i can run the carb lean enough to pass. I will try to post pics of it later, but any advice on how your air injection system is connected will be helpful. BTW it is a 85 Grand Prix in which i swapped the 305 to a 350, Edelbrock 1405 carb, Hooker headers with the air injection pipes with 2.5 pipes, dual cats, and 02 sensor hooked up. I have looked in my Haynes manual and my emissions label but didn't seem to find any info. Help! I have a few days to get it retested and need to see what is needed.THANKS!
