Amp Wiring
84Fourdoor
Jul 18, 2011
53
How do I get the wires into the trunk? Where is the best place to go through? Where should I put the ground? And how should I run my rca and power cables? On opposite sides or what?
Pop up the bottom part of the rear seat, pretty simple to run through when you get that up
You'll see when you pull up the rear seat
I usually try to make it as short as I can, scrape off any paint, make a good connection to clean metal. Most importantly, make sure it's nice and tight.
I always run power and signal on opposite sides to minimize the introduction of noise.
