AN Line Opinion
mikester
3,040
4,060
Small town NY
Quick question.
I know a solid line front to rear would be optimal for a fuel line but Ive got two pretty long lengths of AN left over from past projects. Enough to make the run. Anyone use a coupler in the middle ?
What about a frame mounted inline fuel filter ?
It'll be fine, send it. The AN stuff flows enough. I've got -8 running from rear to a Y block by the engine, then splitting to two -6 lines feeding my EFI rails.
If I recall you're just running a carb right? If so, -6 to the front will be plenty.
Thanks for the reply.
Yeah, its a carb. Ive been fighting trying to get these stupid lines straightened out. I gutted an old fuel pump so I could clock it easier and no matter how its set up the inlet is going to be an issue. The two SS transmission cooler lines are right in line with the steel fuel line so the rubber hose wont fit right no matter how I try to loop it around. Even worse trying to get a filter there.
I returned a Russell AN inline filter the other day because it hits the serpentine bracket. Im thinking a piece of 6AN can just come out of the slot in the frame right over to the pump like I did on the 81. Im going back to the speed shop Monday and Im going to buy a bunch of different angles and hose ends. Maybe even ask about a different filter.
I just wasnt into buying another box of SS hose since I have the two pieces just sitting in a box and Im pretty sure theyre going to be long enough.
A name brand coupler will be fine, I have one up front on my Regal going from the 8 AN filter to the regulator.
On my Monte the filter is attached to the pump in the back so I have a 10 AN running from there to the 4 port regulator up front and then I have two 8 AN lines going to the carb.
