I have a serious wiring issue... I've checked the two grounds upfront and the ground in the rear and they all seem to be making good connection.
My left turn signals and lights work 100% of the time. The running light blinks too is that normal?
When I turn my headlights on the even when the turn signal is not flipped it shows a solid left turn signal ONLY on the dash, nothing outside....
the right side is another story....
When my headlights are on, nothing on the right side works.
When the headlights are off the left turn signal and left running light blink as well as the front right running light, but not the front right turn signal. Also 6 of the 8 lights in the rear blink.
When the turn signal switch was replaced the brights lever accidentally broke but that wouldnt have anything to do with anything else would it?
Thanks, kyle
Thanks, kyle
