I'm starting to look for springs and shocks to get my Lemans frame back rolling again. This is going to be a mostly drag car with some light street driving. Hoping it will be a low 10 second car when done. The motor will be a stroked Pontiac 400, with aluminum heads/intake, 600-650 HP, TH400 trans and a custom fit 12 bolt with 3.73 gears.
Ok, back to the original question. It seems like the cost of the whole QA-1 "R" series kits isn't too bad if you compare it to buying regular front springs with adjustable drag shocks. Then you get the advantage of the adjustable ride height too. I'm really thinking about going this route, but wanted to see if anyone else had used them and would give feedback either way, good or bad. Maybe give a recommendation for which spring rate to get. It will be lighter than typical 400 so I was thinking about going with the 350# kit, rated for 1700# to 1900# front end weight. I'm hoping the car will have a race weight, with me in it of 3400# to 3500#. I'm actually hoping for less, but being realistic. I'm open to suggestions and any help you can give is appreciated. Here's a couple pics of where it sets right now.
Thanks guys!
Troy
Thanks guys!
Troy
