Question for your guys that have used the Astro shaft. When you clock these, do you run into any issues. Clocking the upper 90 degrees puts the yokes/joints out of alignment. Does this cause any issue? Its not really correct, the yokes should be the same on both ends of the shaft.
What you guys have all done is represented in the NO in the image below. I personally think the re-clock of the lock plate in the column is a better idea... Maybe I am missing something though. Input?
