Azn newbie, frm Minneapolis
khmer379
n00b
May 29, 2009
4
just started in the domestic scene i was into import for 10 years so i want it to B different n pik me up a 86 brohaum for 800bucks i just kurious what the best and cheapest way to make a 13 second daly driver without using nos and question bout rearend gear and posi any help would B appreaciate
Welcome!
Nice to see more local folks on here!
If your car still has the original trunk lid, you can look up your rear gear ratio on the RPO label on the underside of the lid.
The rear end codes start with G.
Here's the common G-body rear end related codes...
GH2-2.29 ratio
GM8-2.56 ratio
GT4-3.73 ratio
GU1-2.41 ratio
GU2-2.73 ratio
GU4-3.08 ratio
GU5-3.23 ratio
G72-2.14 ratio
G80-limited slip differential
A 13 second car should be easy to acheive with a simple small block Chevy. What motor is in the car now? V6 or V8?
Welcome to the forum! If you've got the original 307, it's gunna be some work getting it to 13's. Looks like you'll need a new engine, I agree with Blake, go with a SBC. You'll need about 350-400 hp on the motor with correct gearing to run in the 13's.
i have the v6 version am trying to find a shop around here who kan do the sbc swap cheap if you guys know any lemme know n how much would it cost to have a turn key sawp a.k.a plug and play
