So now that my car is mechanically sound, and the body is stripped to my satisfaction, it is time to start prepping it for paint! My goal is to have it ready for paint by Christmas. Currently the majority of the body is at 220 grit orbital. I still have some filler work to do on the roof seams and the B-pillars and in front of the driver's side rear wheel. My plan is to finish the filler work up, use my 16" dura lock and block the rest of the car to 320. I won't use a guide coat on the first blocking. After the body has been blocked to 320, I will have my two coats of primer sprayed. From there I will guide coat and block the car, and if it is straight to my satisfaction, spray color. I don't need a perfect finish, but I don't ant my car to look like the surface of the ocean when you look down the side of it. Does this plan sound about right? Any corrections I should make? Thanks-
