Bolt Size Question
I found this online for the rear control arm.... Is this info correct?
Available at www.mcmaster.com.
95327A712 Metric Zinc Yellow Plated Steel Hex Head Cap Screw, Class 10.9, M12 Size, 110MM Length, 1.75MM Pitch, packs of 1
2.22 per pack
95327A708 Metric Zinc Yellow Plated Steel Hex Head Cap Screw, Class 10.9, M12 Size, 100MM Length, 1.75MM Pitch, packs of 5
11.38 per pack
93795A250 Zinc-Plated Class 8 Steel Conical-Top Hex Locknut, M12 Screw Size, 1.75MM Pitch, 19MM Width, 12MM Height, packs of 25 8.56 per pack
91455A150 Metric High-Strength Steel Flat Washer, M12 Screw Size, 24MM OD, 2.3MM-2.7MM Thick, packs of 50 7.76 per pack
The 110mm bolt is for the longer front lower control arm. The 100mm bolt fits the shorter lower front control arm and the rear control arms as well. These do not have the taper of the OEM bolts on the end, but I had no trouble installing them. The Lock nuts are identical to OEM (except shiny-new).
The radiator support bolts (to the frame) are 98093A652 Class 10.9 Steel Flange Head Cap Screw, M10 Thread, 1.5MM Pitch, 100MM Long
If you want a pair of these, PM me, as I had to buy a 10 pack and I only needed four to do two cars. I can include washers and nuts, although the nuts are on back order at the moment, but they should arrive here by June 24th.
Thanks for the info and I showed this info to my local fastenal and the were able to set me up with the parts... And ssn696 I bet someone will see this thread and contact you for bolts because these bolts are hard to find!
I'll need full set new bolts for cushings, control arms, etc... Does umi sell everything we need for our gbody's?
Your upper front control arms originally had a bolt with a serrated shank below the head gm Part # 461854
Just in case someone wanted to go back that route
