brake booster replacement
81msw79
391
127
roselle park , nj
I need a new brake booster for my 81 Malibu wagon. it has power barkes. I have found 2 different boosters. I would like to know the differences between both.
I found a single diaphragm for normal brakes which is what I I think I have.
I also found a dual diaghram for "heavy duty" brakes.
what is the difference between the two systems? what makes up "heavy duty" brake system?
Your Wagon could have either of these boosters. Most of the V-8 cars had the dual one it is smaller around Than the single. Heavy duty was only on the Police/Taxi cars.
tc1959 said:
81msw79 said:
cool. so what makes the " heavy duty" package special?
Its rare they didn't make many of them. It was an option on the Police cars or Taxi cabs.
I've had my 1980 El Camino for 20 years and is stock from the factory. It's a "plain Jane" with a 229 V-6, 3-speed manual trans., non air and cloth bench seat. It has the dual diaphragm brake booster. Maybe all El Camino's came that way :?: :?:
Doug
Just asking but if you up grade to the double diaphram do you need to up grade the porportioning valve as well or no. My Olds has stock front brakes and 11.5 inch ford drums in the back. Trying to get better brakeing but the pedal has always felt bad even before the 9in went in.
You may find the B-Body dual diaphragm brake booster upgrade interesting. The B-Body booster is almost the same diameter as the single diaphram pancake booster in the G-Body but is as deep as the dual diaphram G-Body booster. There is a thread here by 79malibu: B-Body vacc booster swap,,,,Mon. Aug. 27, 2012 @ 5:11 PM,,,in: chassis/drivetrain/suspension/wheels. ....Or, over on MonteCarloSS.com in the: Do-It-Yourself section of the Technical Discussions forum, on page 2, 3-18-11 @ 7:24 PM is a good swap right-up: B-Body Dual Diaphram Brake Booster Update. ....I'm planning this swap myself later in my resto-mod.
Doug
I have been trying to find that. Im on the web site of course just cant seem to find the write up on the master. You got any more info for me to work with. I could just not be seeing it.
1) click on Montecarloss.com in my post. ...2) when the site comes up, click on: Community Forums. ...3) At the page top, click on Forum List. ...4) Go down to Technical Discussions, find the Do-It-Yourself forum at the bottom and click on it. ...5) click to page 2. ...6) go down 5 lines to: B-Body Dual Diaphram Brake Booster Update.
Doug
