i just installed new cross drilled slotted rotors with new pads and when i brak hard a lil bit it pulls to the right kinda hard. now i've done brake jobs before but this never happen. wat can causing this... is my caliper bad on one side. i dont hear any grindin like one is stuck.
Check the caliper guide bolts and the guide bolt bushings in the brake calipers, and make sure that both calipers can float freely on the guide bolts, and that the calipers aren't sticking or binding on the guide bolts and/or guide bolt bushings. A situation like this can produce similiar symptoms to a caliper with a seized or seizing piston. Good luck.
