Hi there. I'm starting an engine build an I would love some suggestions/advice.
I've got a core from a 1989 350, 1 peice rear main seal. I've got the engine and rotating assembly all disassembled.
I'm looking at a budget build, ideal about 1hp per cubic inch. I've got the block tank'd and mag'd. I'm ready this month to get the block bored .030 over and cam bearings and freeze plugs installed.
The engine will be going into a 1983 Monte Carlo LS.
I'm looking to spend as little as possible, and as such I'll be cruising junkyards and such. However one thing I don't want to skimp on is the rotating assembly and block. I'm debating 355 or 383. I'd like to get as much power/inch as possible, but not break the bank. I can do clearancing and porting myself at home. What is the advantage of the 383 over the 355 (other than cubes and torque). I've heard before that you need to run a longer duration cam to take full advantage of the 383 (due to the faster piston travel). How accurate is this?
I was considering getting a jegs/summit rebuild kit, with a cast crank, hypereuctatic pistons, and buy some rods. I'm not sure what kind of rods I want to use at this point. Ideally I'd like the longest rod I can fit without spending too much money to do it. From what I've read a 5.7 rod is normal (it comes with the kits) and will fit easily.
As far as top end, I'll likely end up using an OEM hydraulic roller cam setup (like out of an IROC camaro), with 1.6 roller rockers. I'm not sure on the head selection yet. I'm interested in trying to port 193 casting heads to see how well I can do, but I just as likely buy a set of cheap aluminum heads from Jegs or Summit.
I'll likely start the build with a Q-jet carb, since that is what is on the car now. Also eventually I'll be using a TBI setup, with a stock-style HEI distributor for now. I've done a carb to TBI swap before on my dads' pickup, so I am familiar with that setup. The car also features a stock exhaust system, again, for now. But likely the engine will change before exhaust. The car also features a TH350 with a 2000 stall.
I currently use this car to cruise, so it needs to have somewhat reasonable fuel economy.
Any suggestions would be appreciated.
