do you have to have a computer to run the electronically run carb or can you rig something up. i'm talking about the cpu run rochester 4 bbl carbs that some of our cars came factory with. i was thinking of stripping alot of the cpu and emisions crap off of my 84 monte as i am rebuilding the engine/trans swap to a 700r4 and restoring the car. is it possible to rig the carb up to run right or not. otherwise i need to buy a carb. yes i will be using a norm vac run distributor.
i also ask the question because i have a beater 82/83 s-10 that needs a carb bad and old one is past shot. it has the crappy 2.0 engine and have trouble finding a 2 bbl carb that isn't cpu controlled for this s-10 doesn't have a cpu running stuff. my idea was to take a working 2bbl of a 2.8 v-6 and have it adjusted to run on the 2.0 but all the 2.8's were computer controlled and i don't have 1 to run it but can i rig it some how?
