can i clip this harness?
85gbody
192
2
34
Long Beach, Cali.
whats going on gbodyforum. i came across a harness while i was working on removing my heater core and was wondering what the are for. im pretty sure it goes to the ecu that was never in the car when i bought i tand was wondering if i can just tear it out. its connected to one big plug that seems to run across the top back of the dash to 2 more plugs that go to the ecu and out the firewall that are many more small plugs that were never hooked up to anything when the car ran (possibly for egr purposes and maybe ac and heater purposes that i wont be using) and then connects to this set of relays which i googled and egr cont and air cont came up on. my actual question is, can i clip this to eliminate this whole harness running thru my engine bay without it affecting anything important. if guages are a factor, im planing on changing them all cus they never worked anyways. sorry for the whole paragraph and if something doesnt make sense i can try to explain as much as i know. thanks fellas, i appreciate any help.
relays
number one the relay
Since its not hooked up to the ECM you can remove the whole harness.
