If there is no replacement for displacement, why are we considering even a SMALL BLOCK and not a big block.
I really find this argument as being asinine.
First one must understand what the goals are.
You looking to get over 350-400 H.P.?
If you are then displacement will come into play considering cost ideals, but a lower build big block will yield results with more room to grow for within reason of a larger small block build, like a 350.
Not looking to get more than 325-350 H.P. then the 305 should stay in contention.
The block is all ready ready, saving you a few hundred or more than having to find and purchase the 350 block.
That few hundred dollars equals what extra you might spend on building the 305 against building a 350.
Thats it, not what your hearing now about how much more it'll be with no explaination.
And thats even on the high end itself.
The only more expensive part you'll buy for the 305 will be piston cost, but its maybe $100 more on the high end.
Everything else is shared amongst all small blocks, like cams, head works so on and so fourth.
http://www.popularhotrodding.com/engine ... index.html
http://www.chevyhiperformance.com/techa ... index.html
http://www.hioutput.com/tech/343hp/343hp.html
These are just a couple that have been done and you can vary in different parts and yield lower amounts to higher amounts, but this gives the gist.
All motors once they've hit the 1 h.p. per cubic inch arena start to get expensive.
