oh ok... i believe the upper mounts on the 8.5 are in the place they are on the 7.5tdvick said:I'm sure it's a 8.5". Trying to see if you can tell if it's from a G Body by the position of the upper mounts? Thanks for the info though.
you are correct... the 8.5 is a direct swap from a 7.5... as long as they are both from G-bodies...veltboy314 said:If the mounts were in different locations wouldn't you need different trailing arms or something. From what i was always told the 8.5 is a direct bolt in swap for the 7.5 so thats why i believe everything is in the same location but
khan0165 said:you are correct... the 8.5 is a direct swap from a 7.5... as long as they are both from G-bodies...veltboy314 said:If the mounts were in different locations wouldn't you need different trailing arms or something. From what i was always told the 8.5 is a direct bolt in swap for the 7.5 so thats why i believe everything is in the same location but
but other cars used 7.5s and 8.5s too... so that's where it gets tricky. Cuz other vehicles like A and B bodies had different ears and spring mount locations than our Gbodies.
