Coming off a fresh rebuild here. Here is what I got and the ending result to fix. My question will it last?
Buick 350
Fresh rebuild
Oil pan gasket, tried fel pro Cork, nada.....Due to mounting surfaces for the bolts were higher that the mounting surface of the pan. So, I corrected it with some delicate pursuasion. The pan is straight and all bol hole areas are now below the seating surface of the pan. Next, Victor Reinz gasket, RE: It contains rubber and cork, is thicker and is a better gasket. There is no rubber/steel option available for the Buick 350. I applied a very small amount of gasket maker only to the areas that the pan was leaking before ( at rear sump area) and also did this due to the recess that the rear main seal piece mates to the block as well. Still, a small, very small leak. It seemed the gasket was letting the oil through the cork around this mating surface. so.....pissed off i placed a small amount of gasket maker on the side of the pan, let it set up for a moment, and wiped the area dry. No leaks..I applied a little more, kind of like what we do when we caulk a bathtub to this area, which is about 1 to 2 inches. No leaks. Do you believe that it will stay dry?
Only thing left to do is spluge a crap load of gasket maker and try it as well. I'd rather stick with a gasket if all possible. WHat a PIA.
Buick 350
Fresh rebuild
