Changing my 81 Malibu Landau to a regualr 2 door coupe
i bought a 81 Malibu Landau that i am going to make into a nice street car. i am in the process of the body work right now and i heard from a buddy of mine that i can change it from a landau to a reg 2 door coupe. i wanted to see if anyone had any info on how to do so. this is my first landau and my 5th malibu, all the others have never been a landau. my buddy said something about removing the spot welds on the glass panel on the side and putting in a 2 door coupe glass, i wanted to check before i had done so and see if there was anything more to be done. thank you.
Doober
1,253
20
38
Swartz Creek, MI/Tucson, AZ
He'd be correct. I'm pretty sure you also need a different 1/4 window trim panel on the inside, and the trim along the bottom (and obviously the front) of the 1/4 window are different as well. It's been discussed before, so I already have pics ;) The vinyl was already removed on mine, they just didn't replace the panel (similar to yours most likely).
O. D. Showtime
3,005
3,533
Regina Sask. Canada
jonnyslick said:
What's the difference between the two from the outside? Does anyone have a side pic of both?
Here's a couple of pics. Hope it helps.
The landau I had.
My son's coupe(old pic)
Doober
1,253
20
38
Some guys have made plates to replace the 'Landau' panels as well. I think I'm going to remove my welded in panel & go with a non-landau setup though, helps make the windows look a little more streamlined.
Phoenyx
2,392
7
Alberta, Canada
I kinda like the landau version. It would look good with the back windows tinted.
Doober
1,253
20
38
jonnyslick said:
Man .. I really want a Malibu now. I'd love to have one with a LS engine and a 6 speed. Yummy.
That's my goal ;) Planning on a 6.0/T56 Magnum... maybe even a supercharger, but that would probably be down the road after everything is running.
