i have a olds calais wit rocker chrome and i have no idea how to remove the chrome off the doors does anyone know how?
85 Cutlass Brougham said:I, the all knowing forum geek, will show you the path to enlightenment and answer all of your existential quandaries. Then again...maybe I'll just answer the technical question at hand.
It's really quite simple. There are 2 speed nuts on the door, one at the front, one at the rear. These hold the attaching studs for the trim piece and you have to remove them. Next up, you simply push the trim piece upwards slightly from the bottom and tip the top outwards after moving the trim piece upwards around 3/16 of an inch. Just don't force it up too much as it will break the springy part of the nylon attaching clip.
