hey guys to me the front coil springs in my car make the ride height look to high, i have small block 350 springs in it, would it be ok if i used springs for a 307 or 305 to make the ride hight a little lower in the front??
Intragration said:If you change to V6 springs, it may lower the front, but it will also lower the spring rate a bit and cause it to handle worse.
