Condenser mounts?
84cutspreme
1,163
158
Does anyone know if the mounts for the v6 condenser are the same as the V8? Also are the mounts for the V8 cutlass and monte carlo condensers the same...I am under the impression they are, just lines are switched from passenger to driver side on montes?
The mounts are the same, but the condensers vary by year and application.
OK thank you very much...I have the V6 supports from mine, but putting in the monte condenser I figured it would be another little thing to buy like the radiator isolators.
I could have used the V6 condenser when I did my swap, but I had a HO 305 Camaro unit in better condition that I used instead. It also fits better with the factory dual snorkel air cleaner base from the same Camaro. I basically did all my brackets, hoses, etc. around the concept of using that air cleaner base and having it look stock. Plus, it didn't hurt that I already had the right stuff. If I were to try and find it all it would be difficult to source it.
