coolant route
jeremyandthemonte
731
150
hello fellas i am looking for pictures or any info on running the coolant lines. i have taken the a/c and heat out and want to know what lines i have to run
You've taken the heat out as in you've removed the heater core entirely? Keeping it out or replacing it? Size and type of engine? Need more info.
sorry i have a 350 sbc stock intake i just took out everything that has to do with a/c and heat i dont need it i have a electric heat box hooked up to my windshield defrost.
Ok, in that case, all you need to do is get yourself some pipe plugs and install them in place of the pipe nipple on the top of the waterpump and in the intake manifold where the heater hoses attached. Plugging off the heater hose points won't affect anything else.
The a/c side is its own deal. If you've removed the compressor, condenser, and all your hoses, all you're left with is plugging up the hole in the hvac box where everything went in. If you still have the vacuum lines in place for the a/c system, they will need to plugged off or removed as well.
