cruise control cables
Cutty1
412
2
40
metro detroit
i'm deleting my cruise control and the 2 cables that screw on the control device , so where does these two cables go looks like through the firewall and where do they end at? oh also theres a vacuum line where does that lead?
i have no heat in my garage and i havent actually looked to hard to see, i'm just wondering how those cables get ripped out
You will need to replace the two cables with a single cable that goes from the transmission to the speedometer head.
There is a single vacuum supply hose that is connected to manifold vacuum; remove the hose and cap that fitting at the source (should be a multi-port fitting at the back of the carb base).
The hose that goes through the firewall grommet is connected to a vacuum switch on the brake pedal pivot bracket; you will be able to remove all of that if you're permanently deleting the cruise control.
