Cruise Control Delete
othtim
392
16
Hello there. First thread!
I am currently trying to remove my Cruise Control. However, I don't know what to do with the cruise speedo cable. When I remove it the speedo does not work. Is there a process I can follow to disable this second speedo cable so that I can use my speedometer, and delete my cruise control?
Thank you.
depends on the car, which you didnt mention, but you probably can get a normal non cruise speed cable as a last resort.
Sorry about that.
It's a 1983 Monte Carlo. It is not an SS.
othtim said:
Sorry about that.
The cruise is inline with the speedo cable. You need to remove both shorter cables and install a single, non-cruise cable directly from the trans to the speedo. Note that the mechanical cruise unit was only used through 1983. Later cars used an electronic cruise module that got speed info from the VSS. Thus, the cable from any 1984-88 G-body with the same trans should work fine (though be sure you have a cable with the correct attachment at the speedo head - some snap in and some screw on).
Thanks. Next time I'm at the boneyard I'll see what I can get. I really appreciate the response.
anybody have a part number for this? I'm too lazy to get my cruise to work again, and it would clean up my engine bay even more so why not? :lol:
