Cruise control
83ho87gn
11
Hey guys, I have an 83 HO, trying to get my cruise working again, I put in a new turnsignal switch hoping that would help, but nothing, can someone give me a run down of what to troubleshoot and where to look, I tried to find the fuse but where it says cruise on my fuse block theres nothing there not even terminals for a fuse if that makes sence, it worked when I first got it. Just cant figure out why nothing now
Thanks in advance!!!
Have you checked your cruise control vacuum lines for leaks and proper routing?
Also have you checked the cruise control lever?
Thanks for the quick reply!!! I just figured it out, so looks like I got it under control from here, thanks again!!
Glad you got it working, what was the problem? How about a summary of problem and solution, just in case it helps someone out down the road? 😀
