Cutlass Fan shroud
SafariWagon
390
11
What's different about the cutlass fan shroud compared to the Malibu? Malibu seems to be one piece completely made of plastic. Cutlass seems to have a plastic piece and a steel plate at the top for the radiator. Is the location of the hole for the fan also at a slightly different height?
I have a 2 piece with out the metal plate I got new from GM, I believe it is from a Monte......
mmmmmm plastic 2-piece on my malibu original 305 car
You guys are right. I guess I mean 3 piece as compared to a two piece. Malibu- Monte two plastice pieces.......upper and lower riveted or bolted together. Cutlass has the same thing in addition to a steel plate for the radiator. My question is the opening for the fan higher in the cutlass? I have a malibu fan shroud and the fan hits the top of it. I have a pontiac 400 installed with 301 motor mounts. Can't find a V8 grand prix or lemans shroud. But I can get an olds V8 shroud. I need about 3/4 of an inch. Is there a difference that anyone knows about?
