cutlass lights
stocksuspension
6
anaheim
does anyone know if front headlights on an 87 cutlass fit will be a direct fit on an 85 regal? also were can i find door window weather stripping?
Are you talking about the headlight bezel? I believe the bezels are the same on the Regal and Cutlass, and I also believe that the bulbs are the same if thats what you meant.
eBay has to be the best place to get weather stripping for cars. Its cheap and abundant.
If you are talking about the 87 Cutlass Euro composite lights, then no - not even close.
That is not to say that SOMEbody MAY have tried it in the past, but not without major cutting and fashioning of the header panel i pressume.
You would also have to do a major cut up of the bezels on your regal as it would not fit around the headlight at all.
Weather stripping should be available from multiple sources for the 2 door.
I have found 4 door weatherstripping sitting in dealerships by doing a GMpartsvoice search. Need to know the part number first thou. Never tried looking for 2door weatherstrip on PartsVoice.
IIRC, it won't work. The Regal has a raked prow while the Caprice is blunt.
That is, if you mean the bezel.
