Cutlass to ss
Boy1duh
Feb 11, 2016
5
8
38
Will most 442 parts fit into my ss looking at a beater 442 for parts only thanks
The rearend would probably be the only worthwile takeoff to use on your SS, maybe some suspension parts. The rear should be an 8.5 if its original and would be a big upgrade.
Cool how bout the floor shifter my ss currently has no shifter
You should be able to put the shifter and console in your monte. You will have to get the mounting perches from the floor of the 442 and tack them to your floor and you will have to drill a hole for the grommet for the shift cable.
you could pretty much swap the whole interior except the sail panels (assuming both cars are solid roof or both t tops).
I would hold on to the transmission if stock, I believe it had a better valve body than the ss.
