Damn it
Bri guy
845
225
37
Was told to order this part...went to put it on and realized there different. Can it work or do I need to bring it back. It' a fuel pump on 403 olds
Should be a part number on the old pump. Or try and look for one that's right I guess. It's not installed, no gas through it, so you should be able to return it to wherever you got it from. Looks like there's an in, carburetor out, and a return? Make sure you get one with all the nipples needed. Run the MF0006 pump's number (three line pump) through your local parts store's website, see if they carry it.
https://www.rockauto.com/en/catalog/oldsmobile,1977,delta+88,6.6l+403cid+v8,1214042,fuel+&+air,fuel+pump,6256
Any other of the three line pumps would do as well.
Reactions: fleming442
